This command sets the time to wait for an acknowledgement of a transmitted LSP on a point-to-point interface.
vlan all | Applies the timer value to all IS-IS VLANs. |
vlan_name | Specifies a single VLAN to which the timer configuration applies. |
seconds | Defines the timer value. The range is 0 to 65535 seconds. |
5 seconds.
If an acknowledgement is not received when the timer expires, the LSP is resent and the timer is reset.
The following command sets the retransmit interval for the SJvlan to 10 seconds:
configure isis SJvlan timer retransmit-interval 10
This command is available on platforms with a Premier license as described in the Switch Engine v33.1.1 Licensing Guide document.
